2010 Chevrolet HHR Panel LS Rear Speaker Wire Colors
I'm going to install a Line Converter (High to Low Level) on a Stock Base Radio. Could someone let me know which are the Rear Speaker wire Color Codes. I tried to use the info at:
http://www.modifiedlife.com/2010-che...-wiring-chart/
However this site does not indicate the trim level that their system calls out. When i tried to find the wires as noted I found no Brown wire.
I would like to pick up the wires under the Passenger Side Kick Panel rather than behind the Radio. I will locate me small Amp under the Passenger seat.
Can anyone assist to facilitate this plan?
Thanks!
Thanks!
I believe its light blue/dark blue. On mine the speaker pairs are twisted together, easier to identify them.
Edit: diagram posted
https://www.chevyhhr.net/forums/show...20&postcount=6
OK, I checked under the front kick panels on each side and still was not sure. Then, I removed the rubber grommet were the wires go into each back door and found the wires that you referred to.
Last question is on each side which is the positive and which is the negative? then I would be all set.
Thanks again prod!
Thanks again prod!
from the post I linked above, the dark blue and brown are the positives.
If you pull up the plastic trim at the bottom of both front doors and look under the carpet, you should see the wire bundles, might have to unwrap the electrical tape to see those colors. Saves you running wire up and down the rear door pillars.
BunglerHHr
Sep 25, 2012 12:04 AM
