adding my subs to a factory stereo
Old Sep 1, 2010 | 12:20 AM
johouse05's Avatar
I have a set of jl subs and a rockford 300.1 mono amp and I want to install them into my hhr. problem is I have a stock radio and have never done an install on a factory setup. anyone got a how to or anything?
Old Sep 2, 2010 | 01:35 PM
johouse05's Avatar
please anyone? I have 600 worth of subs and 400 worth of amps just sitting in my garage that need a home in the hhr
Old Sep 3, 2010 | 12:20 AM
prod's Avatar
Did you try reading the sticky thread at the top of this forum titled "How to install an amp and subwoofer setup"?
Old Sep 3, 2010 | 05:44 AM
jimpennjr's Avatar
From what I've seen and heard this is the easiest way to add amps and subs to a stock stereo. Link http://www.autosoundcentral.com/PAC_...oemgm1416a.htm
If you get it let us know how it is. Hope this helps
Old Sep 3, 2010 | 11:20 AM
Timewalker's Avatar
Yeah, it really depends on whether or not you have a basic stock stereo or the premium stock stereo with amplifier and subwoofer.
Old Sep 14, 2010 | 09:58 PM
HokieHHR's Avatar
Cool
where should i hook the remote wire in my basic single cd system? I have it attached to the amp fuse in the passenger side fuse box but have to unscrew the remote wire from my amp after every trip to prevent the constant power to my amplifier. Which fuse is only on when the key is turned to ACC or the engine is on? I've tried several fuses and wires with no luck to the automatic shut off...
SouthLyonHHR
May 9, 2014 07:00 PM
Robert617
May 4, 2011 10:45 PM
joshua_arndt
Sep 26, 2008 07:38 PM
chingchonger
Aug 28, 2007 04:15 PM
sac30905
Oct 19, 2006 12:27 AM
