Aftermarket double DIN Pioneer stereo install. PLEASE HELP!!!!
I've read the instructions and have done all it says to do. I never listen to the radio, only mp3 and the occasional CD. Every wire from the harness is hooked up properly. the issue is I can't even get the lights to the stereo to come on I get no power.
If the fuses are ok, and it is wired up properly, then either the adaptor, or the radio itself, are defective OR there is still a fuse that is needing replacement..
Have you tried attaching 12v to the radio with it grounded - but first use the car's wiring that is attached to the adaptor (ie: bypass the adaptor)......... once that is done then test the radio under the hood attaching it to 12v and ground?
You say you have installed 100's of radios over the year - so surely you must have a Volt/Ohm Meter which would be the first tool to use in the diagnostics?
Magic is the keyword for sure. I don't understand this situation, as the essential tool that I would have handy when doing a project like this one, is a multimeter. It would be used to double-check power, grounds etc..
In case anyone wants to RTFM, here it is... https://www.pioneerelectronics.com/P...+OWNERS+MANUAL
Any body remember what a library is ?
How about a card file ?
