Shallow Subs
Old 08-21-2008, 07:58 PM
IgottaWoody's Avatar
Shallow Subs
After reading till my eyes bled..I have to ask..has anyone used or considered using the new shallow type subs in the stock location?? JBL GTO
..Alpine Type S... Kicker CompVT.. JL Audio W1v2... MA Hard Core.... Kenwood Excelon Flat .... Pioneer TS shallow... are all thin subs..Most offer 8" though It may be possible to adapt a plate to do a 10 with out major space problems..all about 150 watts and up...and a small tad over 3 " deep....they even have a few 6.5's..maybe fro the rear doors?..Input..neeeeed input!
IgottaWoody is offline
Old 08-21-2008, 08:14 PM
1Panel2NV's Avatar
I'm sure you could do it, but I personally don't think it's worth the time.
1Panel2NV is offline
Old 08-22-2008, 10:00 AM
prod's Avatar
A couple on here have 10" in the stock location, but I think you would need a custom made box, its a complex shape.
prod is offline
Old 08-22-2008, 10:08 AM
atlhhr's Avatar
Shallow sub
I use the Kicker 8"(08CVT84). in the factory box. The sub runs off a separate Kicker sub amp(ZX300.1) The sound is pretty OK. It's about the limit of what my wife can handle so I use that as an indicator of how much bass I get. Eventually I plan to go to the new JL Audio shallow sub(12") once I research the size requirements of the enclosure. So if you like a good bit more bass than factory then adding the shallow sub is not a bad option.
atlhhr is offline
Old 08-22-2008, 12:38 PM
damronjr's Avatar
I was thinking about the same thing. The stock Pioneer really doesn't sound like a sub at all, I have a 10JLW7 but I know it would never fit, but I imagine I would go JL if anything to get the max bass out of the space requirements. I don't want to chop anything up, just find something that will bolt right in where the stock will come out.
damronjr is offline
MurderMittenSS
11-08-2013 08:55 PM
saturnsw2
Mods - Exterior
7
08-05-2011 03:39 PM
roofer1976
02-20-2009 09:53 AM
Airborne_Beachbum
04-16-2007 04:46 PM
longhorn
12-28-2006 12:37 PM
Quick Reply: Shallow Subs
