Audio volume goes down by itself
Old Oct 27, 2010 | 10:04 AM
kkm2517's Avatar
I just had a repair on tires, wheel bearing, and front bumper from my dealer recently. Then a week after, while I was driving for 80 m/h on highway, audio volume just goes down by itself!
what's happening!
Old Oct 27, 2010 | 11:57 AM
ufvj217's Avatar
The dealer must have reversed the polarity when they put the wheel bearings on.
LOL jk, thats odd. im curious to see what the issue is, too.
Old Oct 27, 2010 | 12:09 PM
Some of these systems have a speed sensitive volume, but it shouldn't go down at speed I wouldn't think........ This can be enabled/disabled if you have it.... check your manual.
Mine has it but I don't use it and really don't know how it reacts and don't remember where the "enable/disable" was located (Driver's settings in the DIC, or preference settings in the stereo)
Old Oct 27, 2010 | 03:15 PM
ResalynHHR's Avatar
I believe it's in the preference settings in the stereo. Had that in my Impala, and the only time it went down was when the speed went down..... Or if I really gunned it to pass someone, the volume would go up and then back down when the engine quieted down a bit. Your situation doesn't sound quite right, though, it's really odd......
Old Oct 27, 2010 | 05:30 PM
db/sb's Avatar
You have some kind of malfunction going on there. Some have mentioned SDV (Speed Dependent Volume) like my 2005 GTO has but, as far as I know, HHR's don't have that. That and the fact that, as mentioned, the volume would go up as speed increased not down.....
Old Oct 27, 2010 | 05:43 PM
My HHR does have it, ('07 "premium sound system" from the factory) I just don't use it..... and yeah volume shouldn't decrease with speed. (unless there was a great sounding V8 under the hood )
Old Oct 27, 2010 | 05:55 PM
09 Silver Bullett's Avatar
It is called (SCV) Speed Compensated Volume. There are 4 settings, Off, Low, Med, or High. On my 09 manual, user instructions begin on page 3-65.
Old Oct 27, 2010 | 05:59 PM
db/sb's Avatar
Ours is an 06 with the base stereo. It doesn't have it.
Old Oct 28, 2010 | 12:17 AM
terryk's Avatar
Could be a stuck steering wheel control or a short in the clock spring or contacts (I don't know which is used in the HHR) in the steering wheel.
Randyp
Nov 25, 2013 06:48 PM
taylor7todd
Apr 8, 2012 01:49 PM
caddytruck
Mar 20, 2007 08:26 PM
bluehhrjay
Jul 12, 2006 06:50 PM
adamlowery
Nov 28, 2005 10:21 PM
