Bad fade and balance
Old Sep 26, 2018 | 11:45 AM
Bigjohn1962's Avatar
Hey I guys, I just bought a 2011 LT. It has the factory radio. The right side of the balance is gone (extremely faint. Barely can hear the music) and the front and rear fade is screwed up...Front only works. I decided to put in an aftermarket single din outfit so I bought a stereo, mounting kit with new harnesses, antenna extension and the interface module for the alarms etc. But before I do all of this, I was wondering if there is anything I can check ( I'm new to HHR's ) or is the head unit shot and needing replaced?
Thanks in advance.
John
Old Sep 26, 2018 | 01:56 PM
Speakers are typically the problem
Old Sep 26, 2018 | 01:59 PM
It would probably be a good idea to replace them also I guess.
Old Sep 26, 2018 | 02:00 PM
X2 what greybeard999 said. Its more likely that a number of speakers are needing replacement. They are often a source of failure.
Old Sep 26, 2018 | 02:02 PM
Thanks brother. I appreciate the advice. This is the first HHR I've ever owned and had no idea.
Old Sep 26, 2018 | 02:23 PM
Welcome to the site, x2 in the speakers, I suggest you change them first , you might not need to replace the HU
Old Sep 26, 2018 | 02:29 PM
Thank you. It's great to be here :) I'll try new speakers first. I was accustomed to the old stereos (I'm 56)...In the old days when the fade and balance were bad the borads in the radios were bad. I know NOTHING about the newer circuit/compute stuff....lol. Thank you again :)
Old Sep 26, 2018 | 02:39 PM
The boards and circuitry are similar, the speakers get wet , living in those cold doors! Condensation and vibration kill the speaker cones and corrode the speaker magnets and baskets
SmootHHR
Jan 9, 2019 12:12 PM
PaperChaseHHR
2.2L Performance Tech
Oct 10, 2013 09:26 AM
rotaryboy23
Sep 6, 2010 10:54 AM
Chief Perry
Aug 30, 2009 08:33 AM
robotworkshop
2.0L Performance Tech
Sep 12, 2008 05:39 PM
