does anyone know where the door lock relay is located?
Old Jul 16, 2009 | 10:29 AM
impulse91's Avatar
or the wire colors and locations to tap in too?
I need the negative pulse from when the lock button is pressed on the remote key fob to lock the doors.
I need this connection to trigger a auto window roll up module.
I see the relay in the wiring schematic but i have no idea of the location or wire colors.
any help would be greatly appreciated please.
2006 LT
Thank you.
Old Jul 16, 2009 | 08:57 PM
Sno White's Avatar
The relays are located within the BCM itself and thus are basically inaccessible. The wire for the doors to lock is held to ground normally and switched to Battery Voltage to lock. The wire leaving the BCM in a 2009 is on Connector X3, terminal(s) A4 & A5 according to my FSM.
I have a question for you. Are you really going to go through the hassle of stringing heavy gauge wire into each of the doors for the window module as most instructions say to do? Or are you tapping into the switch module in the center console? I notice you have a 2006, mine is a 2009 and has a totally different window system.
The door lock I assume is the same between the 2006 & 2009. Any commenters?
lewis55901
Dec 11, 2013 12:35 PM
zuni
Nov 13, 2013 04:32 PM
06Daytona
Sep 28, 2009 06:09 AM
Chevy SS
Jun 17, 2008 11:51 PM
TX-HHR
22
Aug 2, 2006 07:19 AM
