Factory LS Amp
After i install the aftermarket cd player and want to install an aftermarket speaker amp, how would i connect the amp to the speakers without having to run new speaker wire through each door?
But really, if you disconnect the rubber thingy (sorry for the techical terms) and run the wire in three steps, its not too bad for the rear doors, the fronts are a bit more trouble cuz you have to deal with the dash too.
disconnect grommet
thru door opening
thru grommet
thru body opening
reconnect grommet
goetylsd
18
Jul 24, 2010 03:20 PM
