Factory LS Amp
Old Jun 23, 2007 | 04:24 PM
ng8650's Avatar
Originally Posted by shaginwgn
You forgot "Another quality post by ng"
My bad
Another quality post by Ng!
Old Jun 23, 2007 | 05:10 PM
CZiggyHHR's Avatar
Originally Posted by GDZHHR
As much trouble and as little real difference it will make, you may wanna go ahead and change out the HU if you're gonna do all that work.
BTW...................
After i install the aftermarket cd player and want to install an aftermarket speaker amp, how would i connect the amp to the speakers without having to run new speaker wire through each door?
Old Jun 25, 2007 | 01:09 PM
CZiggyHHR's Avatar
Bump
Old Jul 6, 2007 | 08:19 AM
LUHHRCH's Avatar
Its not too hard to Run new wires thru the grommets, especially if you use the method I did..... "Hey buddy, can you run these wires thru to the doors while I wire the amps?"
But really, if you disconnect the rubber thingy (sorry for the techical terms) and run the wire in three steps, its not too bad for the rear doors, the fronts are a bit more trouble cuz you have to deal with the dash too.
disconnect grommet
thru door opening
thru grommet
thru body opening
reconnect grommet
goetylsd
18
Jul 24, 2010 03:20 PM
HCSO249
Sep 19, 2007 01:52 AM
