Factory Pioneer amp
Old Jul 29, 2018 | 04:31 PM
OMNIPRES3NCE's Avatar
Factory Pioneer amp
Of the 3 connections on the factory amp, which connector is the signal out to speakers?
Old Jul 29, 2018 | 05:08 PM
Old Jul 29, 2018 | 05:35 PM
If you can't figure out the schematic.......it should be the plug with 8 wires. 4 regular speakers times 2 wires per speaker.
Old Jul 29, 2018 | 05:38 PM
Connector X2
Old Jul 29, 2018 | 05:58 PM
Appreciate it. I've seen these schematics a few times however until I printed these out, deciphering them was hard to follow (99.9% of my browsing is done on my phone). Correct me if I'm wrong, but I can tap into pin#8 (pink wire) for remote turn on for my aftermarket amp? Also, is there a manufacturer (Schoshe, Metra, etc...) that produce a female harness clip that fit the stock amp connecting? If so, I realize that it will probably need to be repinned.
Old Jul 29, 2018 | 09:04 PM
The pink wire is the "radio on" signal.
If you are bypassing the OE amplifier just follow the color codes. What "tapping"?
A very good source of info and parts is crutchfield.com. I bet they have a harness to the HU, if not the amp.
bugflipper
Apr 16, 2010 09:03 AM
misterjensen
Jul 23, 2007 08:47 AM
dbfruth
Aug 8, 2006 11:23 AM
