Instructions to install aftermarket Amp and Sub
Old May 4, 2011 | 12:05 PM
  #31
BigEL44's Avatar
Great write up. Saved me some $ and time as well. It only took me about 40min to wire everything up! Just a quick hook up for now. Hope to replace HU and all wiring in near future to really get my HHR Shaking!!!!
Old Dec 8, 2011 | 08:04 PM
  #32
Dartmech's Avatar
So can you get the 4 wires to the 2 rear door speakers from the harness under the passenger carpet? Also, to me "splice" means to make a "Y" basically stealing the signal from the existing speaker wires. This should allow the rear speakers to remain functional and provide the signal to the line out converter. Is this right or do the rear door speakers get cut out to provide the signal?
Old Dec 9, 2011 | 02:05 PM
  #33
07azhhr's Avatar
I can't answer your Q about the harness under the carpet since I have the amplified system. I can tell you that you will be able to retain the rear speakers and just TAP or in your words splice into the factory speaker wires to get your imputs for your line level converter. Like you are thinking you just want to TEE off the speaker wires over to your converter and still have the rear speakers connected.
Old Dec 9, 2011 | 08:14 PM
  #34
Dartmech's Avatar
Thanks! That's the info I was looking for, i'll get to the wires one way or another.
Old Mar 31, 2012 | 02:25 AM
  #35
HHK7's Avatar
Thanks for this write up
I'm gonna try this tomorrow!
Old Mar 31, 2012 | 06:38 PM
  #36
Andy2.0's Avatar
Good write up!
Old May 31, 2013 | 12:52 PM
  #37
mostwanted1972's Avatar
hi i have a 2008 hhr i want to install a amp and sub on stock unit but dont no were to put remote wire please help
Old Jun 14, 2017 | 11:32 PM
  #38
Jay Inkk Stylzz's Avatar
Originally Posted by Gooch
How did you guys get through the firewall with the power lead from the battery? Is there a double super secret spot, or did you just drill? If you drilled, where? I have installed several amps in my life, but never in my new car... I am experiencing a little "pucker factor" . Thanks in advance for your help!
hey bud the battery for the hhr is in the trunk same with my last car a Chrysler 300
Old Jun 15, 2017 | 05:06 AM
  #39
Hope you realize you're responding to a post from 11 years ago. The time stamp on posts is above each posters name, top left corner.
Besides that, Gooch hasn't logged on here since 2006.
Old Jun 15, 2017 | 08:30 AM
  #40
And his question was answered wayback.
