Instrument lights on continuously?
Old Jun 25, 2014 | 08:04 PM
manicrodder's Avatar
When I walk up to the car in the morning or evening, the lights in the cluster around the radio are on. I haven't used the remote or otherwise unlocked the door. Is this normal?
Old Jun 25, 2014 | 08:51 PM
Nope.
Old Jun 26, 2014 | 12:33 AM
Definitely nope.
You might try giving your HHR what we call a "Lobotomy". Disconnecting the NEGATIVE battery cable for 30 minutes can sometimes cure spurious/odd behavior on HHR's.
It sounds odd at first blush, but depriving the vehicle of power for a period of time will reset assorted modules to their defaults.
Old Jun 26, 2014 | 05:29 AM
It appears the waterfall lighting(radio area) is on it's own time timeout circuit.
I observed the followings light timeouts on my HHR.
Odometer- 3 seconds
Waterfall - 12 seconds
Interior - 20 seconds starts fade out
I'm with 843de on trying the "lobotomy" reset. Sounds like the BCM or Body Control Module may be suffering a little hiccup.
Old Jun 26, 2014 | 07:51 AM
Thanks to all. I turned auto lights off this am and the lights in question went off.
Old Jun 26, 2014 | 12:43 PM
Auto lights don't function when the car is off, except to turn the lights off. They will go back to auto by default each ignition cycle. Unless you switch the light switch to on, best to just leave the light switch at auto position and let the computer do magic.
Old Jul 12, 2014 | 10:43 AM
I did the disconnect for half an hour last weekend and problem solved.
Thanks for the help!
Old Jul 13, 2014 | 02:36 PM
Oh, Oh, Oh Its Magic!! no really it must be, this remedy seems to clear up many a malady!
rendon47
Nov 8, 2015 12:18 AM
JRGHHRSS08
Aug 16, 2010 08:21 PM
volcycle
Oct 12, 2008 08:34 PM
