keep popping inline fuse on my amp
Originally Posted by slamed87lincoln
...i can play all day with the volume on the factory H/U about 1/2 way up....but anywhere past that for more than a few mins the fuse pops.....
What type of line-level matching device are you using?
i bought the schocse line level converter at walmart...i have the adjustment screws all the way out....could that be the problem?
Be sure to adjust both sides as equally as possible to retain a natural stereo balance. (This is hard to do without having a test tone CD and SPL meter though.)
Give it a shot and post the results...
Originally Posted by SoCalHHR
Yes I'm sure that's the problem. You need to play around with the adjustment to take the level down a bit. The problem is your overall level is too high once you crank things up. Try taking it down a bit at a time until the problem goes away.
So after work tonight or maybe tomorrow ill see what happens
thanks
actually if you read the instructions on the converter it tells you to turn the gain all the way to 0 then slowly adjust it from there..Also you may want to consider a larger fuse.I have a 600 watt amp that uses 2 30 amp fuses so I used a 60 amp fuse inline on my power wire..
