Kicker 8" CRV install in the stock box
my 08' LS didnt come with factory sub.. can i put one in the factory area? what do i need to do to make this work. ive been kickin the idea around for a week or two about adding a little 8'' for added bass
For me it was definitely a worthwhile upgrade...night and day difference in the amount of bass. Also the infinity speakers in the door are very crisp compared to the stock "pioneer" system.
If you don't have the pioneer system you would have to get a sub box and tap into the rear speaker inputs like I did.
Halfpanel you can always purchase a factory sub box from another member or like I did on Ebay. They are listed from time to time you just have to look every once and a while. I got mine for $35.
Are the infinities powered stock or are they aftermarket amped? and is it possible to replace the stock amp with aftermarket in the same location? Probably a wiring nitemare............
Some other subs that also fit in the factory box (with spacers like the kickers and or cutting the opening) that I found in my searching are :
Polk MM 8's and even the 10"
Rockford R1 10" if they make an 8" in this I would expect it to fit
RE Audio 8" but it only needs
Many Pioneers both in 8" and 10" and IIRC there was one 10" with a 5" depth and 95db sensitivity. This sub might actually increase the volumn level when used off the stock amp but that is only a guess.
