Kicker 8" CRV install in the stock box
Old Jan 13, 2012 | 02:21 PM
  #31
bad03xtreme's Avatar
How hard is it to swap out the factory amp? I don't want to spend a ton of cash. I am just looking for a little more bass.
Old Jan 13, 2012 | 03:49 PM
  #32
07azhhr's Avatar
You do not have to "swap" out the amp if you do not want to. You can just not use the sub channels and use an single amp for the sub. Get a line out converter and tap into the rear speakers to get your signal. The sub channels seem filtered down a bit and most amps will have their own x-over that will do a much better job.
Old Mar 8, 2012 | 06:09 PM
  #33
Joshua022's Avatar
Where would I be able to get one of these foam rings to space the panel out? Something I could get at a local craft store or something?
Old Jul 6, 2012 | 07:46 AM
  #34
enterthematrixneo's Avatar
I just put the new CVT 8" in my HHR. It fits perfectly with no spacer needed. Most of the ones here look like they are the older model CVT. I covered the stock box in Dynomat and then carpet to help with the problems that the plastic box presents. Pictures to follow.
Old Jul 6, 2012 | 11:05 AM
  #35
Welcome to the site is there a model # on that puppy?
Old Jul 6, 2012 | 12:44 PM
  #36
IgottaWoody's Avatar
some polyfill inside the box really helps too............
Old Jul 6, 2012 | 01:40 PM
  #37
lafinests213's Avatar
post a pic
Old Aug 15, 2012 | 11:09 AM
  #38
bigjacksauto's Avatar
my 08' LS didnt come with factory sub.. can i put one in the factory area? what do i need to do to make this work. ive been kickin the idea around for a week or two about adding a little 8'' for added bass
Kind of reviving an old post
My HHR did not come with a factory sub
How much work is involved in putting in a factory sub.
My HHR I traded in had a factory sub and the stereo system sounded much better.
Is it just a factory sub and amp I need to install?
Old Sep 5, 2012 | 03:53 AM
  #39
jaytheredneck1's Avatar
Go to wrecking yards and see if you can find one that's gone un-noticed. The sub, box, and amp are an assembly, so if you can find one it's easy one stop shopping.
ngabrielavidal
Feb 24, 2013 01:48 AM
djmoose
Dec 23, 2012 07:47 PM
Digital_Rapture
Dec 31, 2008 04:59 PM
STREET STYLIN' HHR
Nov 2, 2008 09:54 PM
