Looking at changing the head unit
Ok well got a 2007 lt has the pioneer package amp sub woofer in the back .. so I went see about jvc double din radio features I want is Bluetooth, incoming calls , iPhone hookup too . And want to keep the rest of the setup .. ok the radio is 130$ then you got to buy gmos harness on star w/ steering controls 175$ and a dash kit and antenna 50$ and I mean that’s is close to 400$ just to do this and if you want a good install that’s 125$ .. I really think this is outrageous just to change your head unit to get these features just to be 2021 world .. I mean you really don’t want to cut up your harness but man what happen to good o days buy the unit and wire it up ? Just putting this out there and if anybody got input on this stuff I am all ears ..
Get a bluetooth adapter that plugs into the aux power outlet (cig lighter) and broadcasts FM. Many options available. Under $30. BT is cheap, I have a few USB adapters for laptops that cost less than a dollar each.
Here are some.
Here are some.
Yes, Crutchfields is a great source for information and the price isn’t to steep, and they have the technical support. As for cutting into your stock harness, that hasn’t been a good idea since the last century.
Here are some. https://www.amazon.com/s?k=bluetooth...s_ts-doa-p_5_9
With Crutchfield look for open box or damaged box deals. Sometimes there is pretty good savings. And if you do buy a head unit from them they give you a discount on the mounting hardware and connectors. But they also tell you what you need so you can look for lower prices.
