Loss of audio in a particular range
Old Aug 27, 2012 | 10:23 AM
User 11223's Avatar
Unhappy Loss of audio in a particular range
Hi everyone,
I have an '06 HHR with the stock sound system. I was originally having an issue where I wouldn't get any audio in the right side of my sound system when using the aux input (similar to this thread), although I was able to fix it by slowly pulling the cord out of the input until both sides were audible.
I've noticed, however, that in some of my music (playing from an android phone), a particular portion of the audio range seems lost. This isn't like a whole chunk that can be set in the car's EQ, but more of a particular range, I think somewhere in the middle. The music then sounds really strange, almost like a poor radio editing job. I know for a fact that it isn't an issue with the phone though, since the music sounds fine through headphones.
Has anyone else experienced this issue, and/or knows of a solution apart from buying a new radio/sound system?
Old Aug 27, 2012 | 10:27 AM
swerv0428's Avatar
I've had the same problem. Look on eBay for a used radio. Can find them fairly cheap. Or you can go with an aftermarket radio. The aux input is soldered on to the circuit board and is not an easy fix. That's what I have been told anyway. Cheaper to buy a new or used original radio and swap them out.
Old Aug 27, 2012 | 11:11 AM
User 11223's Avatar
Thanks swerv,
So it's just the radio, and not the speakers? At least that sounds like an easier fix!
When I'm looking for a new radio, do I need to pay attention to a particular spec? Like, are there standards in size, connections, power usage, etc.?
Old Aug 27, 2012 | 11:36 AM
swerv0428's Avatar
The stock audio system does have weak speakers. I have also had the two door speakers go out. Does the audio quality sound fine when playing a CD or the radio? It's only when the aux input is being used?
http://www.ebay.com/itm/2006-2011-Ch...r#ht_812wt_922
Here's a link to a radio off eBay.
Old Aug 27, 2012 | 11:56 AM
User 11223's Avatar
I've only used the radio when I wasn't using aux input, and as far as I can tell, the audio is great. Thanks for the link, so is it likely that the aux input (+ sound loss in certain ranges) will be fixed?
Old Aug 27, 2012 | 12:03 PM
swerv0428's Avatar
If it sounds fine when using the radio I would say you have a faulty aux input. So I would go with a used radio. Installation is fairly simple. Just pop off the radio bezel that surrounds the radio and ac controls. Then there should be four screws to remove and the radio should slide out.
If you get the radio and run into problems just post up on here what you have run into. And someone will help you out.
Old Aug 27, 2012 | 12:06 PM
User 11223's Avatar
Great, thanks for the help!
Old Aug 27, 2012 | 12:24 PM
swerv0428's Avatar
No problem. Good luck.
BeanWagon
Jun 30, 2013 10:03 AM
JJ's BLACK SS
Apr 20, 2010 11:34 AM
wagoneer
Tires & Wheels
Apr 5, 2010 03:12 PM
