need help audio wise
Old Jan 18, 2012 | 12:59 PM
1Bad06HHR's Avatar
ok I have the pioneer system in my 06 2lt. was wondering how could i change out the sub and fatcory radio. if so with keeping the xm radio as i do use it alot. would want a small sub i do have a 12 alpine type r but wanna keep the cargo space. so was thinking of just adding a 8 and a amp. read threads with many ways to do this and got confused lol. so any help is apprciated.
Old Feb 7, 2012 | 05:15 PM
SlimHHR's Avatar
many ways to solve the issue, if you want to keep the factory radio with your xm you can add rca line outputs to the factory setup and then run an amplifier wiring kit to the back for upgrading the sub and amp in the factory location.
have you made up your mind what you want to put in the back? the 8 or the 12? be specific on what you want and then answers can be directed to that
-cory
Old Feb 7, 2012 | 05:57 PM
1Bad06HHR's Avatar
gonna do a 8 inch prob need space as it is daily. thx guys guess i'll add rcas for now
Old Feb 7, 2012 | 07:27 PM
SpaceCowboy's Avatar
search feature?
Old Feb 8, 2012 | 10:18 AM
SlimHHR's Avatar
If need be you can fix a trim ring to the plastic panel and create your space for mounting depth of the 8" and still retain the factory location
Cory
OldRed
May 7, 2014 06:24 PM
BoostedSS
2.0L Performance Tech
16
May 11, 2010 07:39 AM
wildman1122
South Pacific
Dec 19, 2009 12:43 PM
HipHotRod
Tires & Wheels
Oct 12, 2009 04:41 PM
VictorySpark08
Sep 5, 2008 11:40 PM
