New speakers
Old Dec 12, 2013 | 07:00 PM
  #31
MsBecky's Avatar
Well , I am thinking you can if you where to plug in an aftermarket harness . You would have access to the car side of every wire in that harness , color coded on top of that . But you would have to purchase a harness and you would NOT be able to check the radio with that harness ..
If you have the Pioneer amped system , then you need to go to the speaker and not the harness behind the radio .
On the speaker leads , with a multi meter check the impedance . It should be reading between 2 ohms to 8 ohms . Dead short and the speaker is bad .
Remove the a-pillar and check that tweeter that is not playing with a multi meter . Then you have found the problem .
Chances are , you need to replace some speakers . 6.5 alpine component's are under 40.00 dollars with free shipping " factory level replacement" .
http://www.ebay.com/itm/BRAND-NEW-ALPINE-6-1-2-6-5-INCH-2-WAY-CAR-AUDIO-COMPONENT-SPEAKER-SYSTEM-PAIR-/290994828460?pt=Car_Speakers&hash=item43c0a4b4ac
Old Dec 12, 2013 | 11:19 PM
  #32
LawDog88's Avatar
When all I want to do is see if its loose connections?
Old Dec 13, 2013 | 02:52 AM
  #33
prod's Avatar
The most common problem for losing sound in the door speakers is getting corrosion where the speaker plugs in to the harness. The doors get a lot of internal moisture build up. Pull the interior panels and check.
Old Dec 13, 2013 | 07:44 AM
  #34
Animosity?
Pull the Waterfall off. Stick your fingers into the A/C vent holes and yank. The HU is sitting right there held in by a couple of screws.
Old Dec 29, 2013 | 03:01 PM
  #35
dblwall's Avatar
Finally got tired of listening to just 1 speaker, so ordered 2 pair of Kenwoods from Crutchfield. Made installation easy, adapters included.
1st door panel took a bit of time, didn't want to screw anything up. But each panel took less & less time.
Next thing will be adding a U2K to get the XM going.
nycamper
May 5, 2014 12:30 PM
StillRockin
Jul 5, 2013 12:07 PM
Chevy_dork04
Nov 7, 2008 02:16 AM
mudd274
Jul 8, 2008 03:35 PM
danny
Nov 27, 2007 11:38 PM
