OEM Satellite Antenna
Old Jun 2, 2006 | 08:57 PM
jerij's Avatar
Originally Posted by ng8650
How's the reception with it painted like that?
Ng
No problem. It's what I'm using with my Sirius Starmate right now. I've ordered the SMB connectors to properly hook up my cable instead of my homemade splicing job.
jerij
Old Jun 2, 2006 | 09:44 PM
joesblackhhr's Avatar
The SIGMA hooks up with suction cups?
NO but there "appears" to be a coating or film on the inside of the w/s around the mirror that "might" prevent adhersion...
Old Jun 2, 2006 | 10:11 PM
ng8650's Avatar
Originally Posted by DaJoker
Was more of a reply to joesblackhhr above, but...
SMB is the technical type of interface that SATRAD (both XM and Sirius) use for their antenna connections. FAKRA is a further shroud around the SMB connector that allows it to "snap" into the radio. Most plugnplay radios use just the SMB connector without the shroud, while most OEM and headunit tuners use the extra FAKRA connection to make sure the SMB holds secure. The FAKRA is basically just a plastic piece and usually has clips that hold it around the SMB connector which can be unsnapped to take it off or the plastic can be cut down so you can plug it into a PNP radio. Make a bit more sense now?
Makes a lot more sense now! Thanks for the info Joker...
Ng
Old Sep 22, 2006 | 02:46 PM
LUHHRCH's Avatar
I think I may have gone cross eyed and missed it... has anyone actually tried the sigma antenna yet?
Id like to know before I spend a bunch of time trying to hide my existing antenna wires.
Old Sep 22, 2006 | 03:11 PM
DaJoker's Avatar
don't believe anyone has tried the sigma yet..
SpaceCowboy
Mar 6, 2018 04:32 PM
Kubrickian
Jun 6, 2008 11:18 AM
xzombiex66
Jan 27, 2008 10:07 PM
Steelcity
Jul 16, 2006 08:52 PM
mikeguru
Jun 12, 2006 10:24 PM
