Pioneer AVIC XX and HHr Question
Old Aug 15, 2008 | 05:11 PM
laborkei's Avatar
I have the Z2 installed in my HHR.
When I turn my headlights on, it switches to night display which is black.
On the Z2, you can adjust the brightness by pressing the "V" button.
It can be adjusted for both day and night modes.
Side note: I just updated my Z2's Hard Disk to the Z3's software with all the new maps for 2008, as well as a 60GB hard drive. Very nice!
Old Aug 15, 2008 | 08:02 PM
bluonyx's Avatar
Just make sure you get the correct wiring harness and the speed sensor, back up light and illum. will work perfectly. I have the D3 in my SS and love it. I need to get the backup camera now.
Old Aug 16, 2008 | 12:20 PM
masterchief1112's Avatar
bluonyx where id you get your mounting bracket, i cant find one for the hhr that is dual din.
Old Aug 16, 2008 | 11:19 PM
bluonyx's Avatar
Here ya go, I got mine from Crutchfield.
http://www.crutchfield.com/S-ebL8cuD...px?i=120953302
Old Nov 12, 2008 | 03:31 PM
Ween's Avatar
bluonyx:
Can you give a list of parts required to install that? I know you need the mounting kit, you also need something to retain the use of the steering wheel buttons. What about XM/OnStar?
Old Nov 12, 2008 | 07:18 PM
damronjr's Avatar
I had a D2 in my Vibe, and since you couldn't take the face off, it ended up getting stolen.
Old Nov 12, 2008 | 09:59 PM
bluonyx's Avatar
#130AVICD3X Pioneer AVIC-D3X DVD Navigation Receiver Package
#120OSLAN04 Metra GMOS-LAN-04 GM Onstar LAN Data Bus Interface
#127SWIPS PAC SWI-PS - Pioneer and Sony Steering Wheel Radio Control Interface
#120953302 GM Kit 2004-Up, DD
That's the stuff I ordered from Crutchfield. They threw in the antenna adapter and because I ordered everything at once they cut the price of the Metra adapter in half.
Old Nov 13, 2008 | 12:57 PM
Ween's Avatar
Awesome. What about XM? It should be possible to reuse the original antenna right? .. so other than the list you described, you only need an antenna adapter and a dremel?
Old Nov 14, 2008 | 03:59 AM
Freightliner's Avatar
I see you guys putting these awesome radios in your HHR's but each time I run them through Crutchfields selector, it always says it will not fit! I even ran the double din adaptor mentioned above and they say it will not fit. What gives?
Old Nov 14, 2008 | 11:29 AM
bluonyx's Avatar
Just need the antenna adapter, Dremel and shop vac! When I cut area behind the radio what a mess. Good thing the plastic is balck so if I missed picking it up it just blended with the carpet. The double din adaptor will fit. You'll need to trim off two tabs on the top but it works great. I tried to tell Crutchfield but whatever. I haven't had any problems with my stereo since the install.
