Premium Audio?
Old May 30, 2006 | 04:33 PM
PDice's Avatar
Thanks for the info !!
I am going to call them myself (got that free Vonage long distance stuff so it won't cost me)
Old Jun 1, 2006 | 07:40 PM
DaJoker's Avatar
Originally Posted by Harpozep
I purchased the premium audio pack for a reason, and one of them was the redundant and very handy radio controls on the steering wheel. I do not want to give them up. Any suggestions. Should I just ignore the car audio guys advice?
I'm planning on using one of these:
http://www.pac-audio.com/products/pr...el%20Interface
Old Jun 1, 2006 | 09:19 PM
Tokyo's Avatar
I'd use the SWI-X... That's what I am using already. A more "universal" than the ALP, you can reprogram it if you decide to change your head unit in the futire. The instructions for integrating either are located here:
http://www.pac-audio.com/swixprogram...ehicles&ID=428
Old Jun 1, 2006 | 09:33 PM
DaJoker's Avatar
Yeah, I could use that, but I'm going with a Kenwood deck with the wired remote controller, and pretty much stick to Kenwood units anyway, so it'll work. Plus I've heard horror stories of the SWI-X and sunlight basically making it useless. With a sunroof that I use quite often, it's easier and more reliable to go with a wired unit.
Old Jun 1, 2006 | 09:40 PM
Tokyo's Avatar
You make a good point. The X, like I said, is universal, so I'm accustomed to using it for almost all my installs. The trick is to locate the repeater LED in a spot that won't get direct sunlight. (I had thoughts of replacing the evil roof mounted LED in Shnog with the PAC repeater LED).
Old Jun 1, 2006 | 09:44 PM
  #26
DaJoker's Avatar
Now that there sounds like a good idea. Let us know if you decide to do that.
Old Jun 1, 2006 | 09:47 PM
  #27
Tokyo's Avatar
I mocked it up to test the location already. In my application, with a flip-out, it didn't work well, because the screen would block the light emitted from the LED, as the sensor sits on the front, non-moving, panel. If I were using a DIN or Double-DIN application, it would've worked fine.
The evil LED on the roof is my biggest complaint about the HHR. I'm not a tall guy (5'8"), and I ride low, so the little death ray burns a hole through my soul (and retinas) at night.
wildman1122
South Pacific
Dec 19, 2009 12:43 PM
CrashMan82
Aug 9, 2007 05:13 PM
mudbilly
Aug 8, 2006 11:34 PM
hvrod
Jul 14, 2006 01:08 PM
Kar Krazie
Jan 27, 2006 11:59 AM
