radio antenna coax
Old Jul 28, 2020 | 01:17 PM
pottsarosa's Avatar
radio antenna coax
Im hoping someone can help me. i have a 2011 chevy hhr LT, as long as ive had this car the radfio worked when it wanted. usually i could wiggle the wires on passenger side kick panel and it would work for a couple days or weeks. this coax had a pc of masking tape on it and when i peeled it off this what i found so clearly the previous owner has tampered with it. can anyone tell me how i can fix this?
Old Jul 28, 2020 | 01:54 PM
Simple fix. Replace the cable.
Old Jul 28, 2020 | 06:54 PM
Yes, and there’s the part number
Old Jul 28, 2020 | 07:29 PM
That part number is for remote entry door lock harness.
Old Jul 28, 2020 | 07:42 PM
Not sure which is the correct part #. This link gives 2 numbers (one is at the bottom of the page)
https://www.gmpartsdirect.com/auto-p...umber=20874644
Old Jul 28, 2020 | 08:22 PM
The part number in the pic may be for the multicolor part of the harness. The coax should be one of the numbers FMG is referencing.
The coax should only affect the actual radio reception. If more than that is cutting out, you have other issues.
Old Jul 29, 2020 | 10:14 AM
pottsarosa's Avatar
the only issue is reception correct. how do i replace? can it be soldered? or new fittings crimped on?
Old Jul 29, 2020 | 10:30 AM
pottsarosa's Avatar
to replace this cable thats pretty much the same procedure as installing a new antenna?
Old Jul 29, 2020 | 11:49 AM
This link gives part numbers
https://www.gmpartsgiant.com/oem-che...nna_cable.html
and send Hellshotrod a PM he probably has the parts you need!
https://www.chevyhhr.net/forums/www....ad.php?t=63306
fonque
Dec 27, 2020 05:13 PM
hilcat
Mar 22, 2019 02:45 PM
Cat Man HHR
Dec 9, 2018 12:38 PM
mudbilly
Jan 7, 2012 10:09 PM
SmootHHR
"How To" Tutorial Library
12
Nov 19, 2010 11:44 PM
