Rear speaker cutting in and out
Old Jan 7, 2016 | 10:04 AM
solman98's Avatar
Originally Posted by bugo
Now the rear passenger side door speaker is working fine. Go figure.
Mine would do that as well. But it will go out again. The speaker is toast.
Old Jan 8, 2016 | 03:41 AM
bugo's Avatar
Question Infinity speakers?
I'm replacing all four door speakers in my '10 with the base stereo. I have done some online research and I keep seeing the brand Infinity come up. Does anybody use these? Are they decent for the money? I'll probably end up spending $150-200 for all four speakers. Is there another brand I should check out first? I'll be buying them from Crutchfield.
I listen to a lot of alternative rock and metal with loud distorted guitars, some electronic music with moderate bass, but very little hip hop and rap with loud bass. I want them to sound good with those styles of music.
Old Jan 8, 2016 | 04:08 AM
bugo's Avatar
And now it's not working again. I'm going to order some new speakers and attempt to install them.
How good are the tweeters in the A pillars? Are they as unreliable as the door speakers? How hard are they to change? They seem to be working fine.
Old Jan 8, 2016 | 04:13 AM
bugo's Avatar
How are these?
Infinity Primus PR6502is 6-1/2" 2-way car speakers ? also fit 6-3/4" openings at Crutchfield.com
Old Jan 8, 2016 | 04:31 AM
bugo's Avatar
I've also read good things about Polk Audio speakers. Does anybody have any experience with them?
Old Jan 8, 2016 | 05:04 AM
  #26
bugo's Avatar
What size is better to get? Both 5 1/4 and 6 1/2 inch speakers will fit. I assume bigger is better, but are there any advantages to the smaller speakers?
Old Jan 8, 2016 | 06:44 AM
  #27
The tweeters in our cars don't go bad very often. It's because of where they're mounted. Inside the cabin area and not exposed to any water.
The door speakers generally go bad because they are exposed to water that drips past the window molding.
Not just a HHR problem. Any car with door mounted speakers can have this problem.
Old Jan 8, 2016 | 09:00 AM
  #28
Here's a list of speakers for your front doors
http://www.crutchfield.com/g_400/All...rs.html?tp=105
This for your rear doors
http://www.crutchfield.com/g_400/All...tml?tp=105&l=D
Now I noticed they offer free mounting hardware so check that out, as for speaker choice that's up to your ears!
Old Jan 8, 2016 | 09:04 AM
  #29
The larger speakers move more air so more sound, but not a discernible amount. Replace with the size you take out!
Old Jan 8, 2016 | 09:25 AM
  #30
Polk used to be the "900 Pound Gorilla" of speakers a generation ago, but the quality isn't there anymore.
No experience with Infinity products, I'd go for the Kenwood units or the Fosgates myself, but my hearing isn't as keen as it was once so I find the OEM Pioneer Premium Audio speakers to be just spiffy for my listening...or Cranking It on the scheduled days.
