Side panel sub installation
Old 05-23-2006, 04:39 PM
JOEK86's Avatar
As you can see I have sub woofers on the brain!
Has anyone on this board sucessfully mounted a 10" sub in the sidewall? I imagine that you would haVe to increase the size of the box as most of the 10" subs need at least half a cube. I would be able to live with a grille if it allows the floor panel to tilt up............
Joe
JOEK86 is offline
Old 05-23-2006, 04:43 PM
ng8650's Avatar
I've brought this up and several members have stated that there isn't enough room for anything more than an 8" sub due to room and airspace. Tokyo/Edo was one source of information...
Ng
ng8650 is offline
Old 05-23-2006, 05:19 PM
captain howdy's Avatar
It is a small weird shaped box.
captain howdy is offline
Old 05-23-2006, 05:23 PM
SoCalHHR's Avatar
Side Panel 10" = no bass. Go for the pre-fab enclosure - you won't be sorry:
I bought mine from THIS guy -great pricing, great sound!
If you need hauling room - just pull it out.
I never do :
SoCalHHR is offline
JOEK86's Avatar
I guess I will find out first hand this Friday! I have the HHR going under the knife!
Joe
JOEK86 is offline
Old 05-23-2006, 05:51 PM
ng8650's Avatar
Joe
What are you going to do?
Ng
ng8650 is offline
Old 05-23-2006, 06:23 PM
JOEK86's Avatar
I'm going with a Focal 11" sub, Focal component 6.5 setups for the doors, an Audison 5 channel amp, and a cleansweep processor.
Joe
JOEK86 is offline
Old 05-23-2006, 07:23 PM
ng8650's Avatar
Joe
What are you doing with the sub? Pre-Fab? Custom?...
Ng
ng8650 is offline
Old 05-23-2006, 07:34 PM
JOEK86's Avatar
I am either building it into the stock side position or into the floor.
Joe
JOEK86 is offline
Old 05-23-2006, 07:58 PM
SoCalHHR's Avatar
There's just not enough cubic volume for a sub that size in the side panel. You might get one in there, but it ain't gonna have low bass...
There's really not enough volume under the rear floor area either (unless you lose the spare tire), for a sub that size.
Best of luck with it!
SoCalHHR is offline
Quick Reply: Side panel sub installation
