Sub replacement - 2ohm/4ohm?
Old Mar 20, 2013 | 11:15 AM
IgottaWoody's Avatar
what he didnt catch was the factory set up is already a DUEL driver system..but, IF it was a single driver at 2 ohms .. adding a DUAL 2 ohm speaker would drop it to 1 ohm and drive the amp, just like he said. Since the factory system is a duel driver, going to a dual 4 ohm will cut your power in half....sorry.
Old Mar 20, 2013 | 12:12 PM
IHHRTHAT's Avatar
So I should out with the extra $100 and get the dual-2ohm-shallow Helix.
http://www.crutchfield.com/p_975E8W/...8W.html?tp=111
Thanks all. X2 to Woody
Old Mar 20, 2013 | 12:49 PM
yep...though, to clarify one point..I said the 4ohm speaker will cut your power in half..should actually read, it will take twice as much power to equal the 2 ohm set.
The factory went 2 ohm because they could use a smaller amp to get the same 'amount' of sound from system. There was a day where all speakers were 8 ohm and it took lots o power to run these..
Old Mar 20, 2013 | 01:02 PM
07azhhr's Avatar
Both ways are correct and actually since we are refering to the factory amps use then the first way was the correct statement. This sub will only get the amp to produce half the power it did with the factory sub.
For the box add polyfill about 1/2lbs inside the box and use some kind of sound deadener to lower the resonence of the box. Tiy wont be able to make it stiff plus the factory sub botls to both the front and the back of the box acting like a brace. Once you go with a non factory sub this brace across the weakest wall is removed.
Old Mar 21, 2013 | 10:45 AM
Ive done the cover and fill and it does make a difference....but its still an 8" sub...I added a 10" in a box for support..
Old Mar 21, 2013 | 09:46 PM
  #26
Eric B's Avatar
Are you strictly looking at shallow mount woofers? If so, Memphis S-Class is a very good woofer and is my personal choice when it comes to a shallow woofer besides the Stereo Integrity BK MIII which is leaps up on all of them.
Old Mar 22, 2013 | 12:01 PM
  #27
IHHRTHAT's Avatar
I could not find a shallow Memphis. I'm told they used to make one but discontinued? Would you/anyone have a link to one?
Old Mar 22, 2013 | 06:55 PM
  #28
hhrumadbruh's Avatar
voice coil configuration is simply to match your amps.
you design your amps and subs around each other.
some amps have more power bridged at 4 ohm. some monos have more power at 2 ohm. it all depends.
Example: RF p500-2. 125w rms x2 @ 4 ohms. 250w rms x2 @ 2 ohms. 500w rms x1 bridged @ 4 ohms
alpine MRP-m500: 300w rms @ 4 ohms. 500w rms @ 2 ohms.
2 ohms isn't always more power on some amps.
Personally I like dual 4 ohm subs because I can get 2 of them and wire to 1 ohm. But really it's just a matter of system design.
Old Mar 23, 2013 | 01:01 AM
  #29
prod's Avatar
Originally Posted by IHHRTHAT
http://www.crutchfield.com/p_142SAC6...-Brackets.html
Used the car selector feature, but it seems that they just send these out with just about any speakers for any car, judging by the comments.
Yeah those are wrong, you might fit them by drilling holes in the doors, but then why bother with adaptors. These are what you need, search ebay for "hhr speaker adaptors"
But have you looked at the factory mounts, based on what others have posted I thought the upgraded pioneer system came with separate adapters.
Old Mar 23, 2013 | 03:20 AM
  #30
07azhhr's Avatar
In the OP's case though, he is using the factory amp which is a 2 ohm per channel x 2 channels for the sub so dual 2 ohm sub is what he needs for this setup.
Yes the upgraded factory Pioneer system has seperate adapters for the speakers. The adapters look very similar to that pic.
