Use existing XM antennae
I have a pioneer XM tuner plugged directly into the factory antenna in the rear of the car...
this isn't hard guys
Finally did it, I removed the panel in the right rear that covers the XM module. Unplugged the antenna (Mine had a tan colored connector) Once you remove that connector, it will plug right into the extension. I got a 10 foot one off Amazon for $10, after cutting a couple places where it was taped to other things, ran it along the headliner, down the A pillar, over the glove compartment, and behind the radio. Where I have the new XM module. I did put some heat shrink around the connector.
Thanks SpaceCowboy!
Thanks SpaceCowboy!
Thanks SpaceCowboy!
Thanks SpaceCowboy!
