Use existing XM antennae
Old Nov 5, 2013 | 07:54 AM
jczboy's Avatar
I have had the same question... And an extender does not connect to the OE connection, Still looking for a good solution, I would love to see pictures of what someone did.
Old Nov 5, 2013 | 07:43 PM
SpaceCowboy's Avatar
it will...take the plastic OE part of the antenna off...then plug your extender or XM tuner box in.
I have a pioneer XM tuner plugged directly into the factory antenna in the rear of the car...
this isn't hard guys
Old Nov 12, 2013 | 11:36 PM
Heavywrecker's Avatar
SpaceCowboy is right, but I believe he means you need to remove the plastic BLUE tab from the XM antenna, and voila! Extend it to your hearts content
Old Nov 13, 2013 | 03:14 PM
right on wrecker
Old Nov 21, 2013 | 07:51 AM
jczboy's Avatar
Finally did it, I removed the panel in the right rear that covers the XM module. Unplugged the antenna (Mine had a tan colored connector) Once you remove that connector, it will plug right into the extension. I got a 10 foot one off Amazon for $10, after cutting a couple places where it was taped to other things, ran it along the headliner, down the A pillar, over the glove compartment, and behind the radio. Where I have the new XM module. I did put some heat shrink around the connector.
Thanks SpaceCowboy!
Old Nov 21, 2013 | 12:17 PM
Glad you got it all set up and working!
Old Nov 21, 2013 | 01:47 PM
Thanks SpaceCowboy!
good job dude!
Old Mar 6, 2014 | 05:41 PM
LazyScamp's Avatar
Can you unplug the antenna from the back of the receiver and extend from there?
miltonfisher
Jan 18, 2014 12:41 PM
Randy_W
Aug 26, 2010 11:35 AM
JOEK86
Jul 21, 2006 04:49 AM
