Abs, brake and traction light
Old Aug 16, 2019 | 03:19 PM
Candace's Avatar
It was my Brake switch circuit
]Hello,
I recently purchased a 2009 hhr LS. The brake, abs and traction lights are on.
I went and got the codes on it today. P0573 was the code that came up. Brake switch circuit High voltage was the reading. The part is $8 at auto zone. Simple fix. By the way if you're having these 3 lights come on AND your cruise control is not coming on then this is the reason!! It tells your computer NOT to activate cruise control because the sensor will not detect the correct speed and could cause you to go too fast and cause an accident.
Old Aug 16, 2019 | 04:04 PM
Thank you , Candace and welcome to the site.
And for future readers here’s that code explanation
https://www.obd-codes.com/p0573
I’m happy to see your problem was resolved.
fastsuv
10
Feb 20, 2019 05:38 PM
slowgo
Jan 24, 2017 09:53 PM
fine69
Drivetrain (Excluding Engine)
Jan 11, 2014 11:18 AM
bobnj
Jun 13, 2013 05:17 PM
socalcyclist64
Sep 12, 2012 11:29 AM
