Abs module replacement
Hello,
I have a 2010 HHR LS with the 2.2.
I need to replace the ABS module and I was wondering if only the module is replaced and NOT the pump do you still need to bleed the brakes? I can't find anything in the search about it. Thank you.
It appears the module is separate, you will have to have it vin coded to your HHR
https://www.chevyhhr.net/forums/prob...lt-2-4l-65123/
Some links and information
