air ride done... almost
Hello,
I am going to start working on my HHR i just bought a coil over kit. I was lookingin to stereo stuff and was trying to figure out a way that i can still use it for a daddy car and get a sub in. I have to say your a genius. Did you have to do anything with your rear floor to make that work or did it factory fit all of that under there?
Also the grille more toward the end pages of the thread i love where did you get it or if you made it where can i buy the stuff to do it myself.
Thanks
Chris :-)
Thanks
Chris :-)
Man you got lucky catching me. Been gone for a while. I took everything out including the storage area and child restraint hooks. Then built a wood structure the size of the strage area. This had to be attached sturdy enough to hold a lot of weight. Buy a piano hinge from a hardware store then use the spare tire cover to make a wood top. Build the box to fit inbetween the top and spare tire. Leave a cut out like the ffactory cover to be able to lift it and find something to prop it up if you need under it. I completely skinned three fingers when mine fell on me. the grille is just steel 1/8" x1/2" steel cut and painted. Let me know if that helps any
https://www.chevyhhr.net/forums/audio-video-17/pic-request-sub-amp-install-rear-cargo-area-28575/ that has the dimensions of my box
