air ride done... almost
Old Dec 10, 2009 | 12:57 PM
  #141
garagebuilt's Avatar
thanks. id like to drive it again sometime
Old May 10, 2013 | 12:32 PM
  #142
Bigbarba's Avatar
Hello,
I am going to start working on my HHR i just bought a coil over kit. I was lookingin to stereo stuff and was trying to figure out a way that i can still use it for a daddy car and get a sub in. I have to say your a genius. Did you have to do anything with your rear floor to make that work or did it factory fit all of that under there?
Also the grille more toward the end pages of the thread i love where did you get it or if you made it where can i buy the stuff to do it myself.
Thanks
Chris :-)
Old May 10, 2013 | 02:23 PM
  #143
Man you got lucky catching me. Been gone for a while. I took everything out including the storage area and child restraint hooks. Then built a wood structure the size of the strage area. This had to be attached sturdy enough to hold a lot of weight. Buy a piano hinge from a hardware store then use the spare tire cover to make a wood top. Build the box to fit inbetween the top and spare tire. Leave a cut out like the ffactory cover to be able to lift it and find something to prop it up if you need under it. I completely skinned three fingers when mine fell on me. the grille is just steel 1/8" x1/2" steel cut and painted. Let me know if that helps any
Old May 10, 2013 | 02:28 PM
  #144
https://www.chevyhhr.net/forums/audio-video-17/pic-request-sub-amp-install-rear-cargo-area-28575/ that has the dimensions of my box
Old May 10, 2013 | 02:49 PM
  #145
Welcome back Gargebuilt.
BigRedGoat
Apr 22, 2011 11:20 AM
heyjoe
Feb 25, 2011 08:43 PM
rmunson
Sep 16, 2009 10:14 PM
trfindley
Jun 14, 2009 07:43 AM
bad03xtreme
Apr 1, 2009 08:15 AM
