Any issues with KYB struts
One disadvantage is cost. Maybe. If you labor is free. You get the stock LS/LT ride height. If they offered a lowered loaded assembly it would fly off the shelves.
I used those "loaded" struts along with the KYB shocks on a 2011 LS and couldn't be happier. Better than new. Wife's daily driver. She'd rather raise the car than lower it.
Links?
In looking at these on Amazon, 1 customer gave it 5 stars but added a comment about different length links. What is he referring to?
Reviewed in the United States 🇺🇸 on April 30, 2022
Couldn't have been easier just be sure to have new links available. I had to cut my old ones off. The HHR has different length links depending on what suspension you have
5.0 out of 5 stars Perfect fit on my 2011 HHR LT and rides better then new.
Verified Purchase
Verified Purchase
They come in 2 lengths. 10 and 12 inches. HHR ‘s use the 10 inch version.
He mentions that HHR have different length depending on which suspension you have. Does the FE3 have different length than the FE1?
20784688Link
HHR. Soft ride suspension. Cobalt. Performance/handling susp. Fe5 suspension. Without SS. Connects your vehicle's stabilizer bar to the control arm or strut Provides roll stiffness to vehicle GM Genuine suspension parts match the GM vehicles original equip ...
MSRP $66.96
$37.83
ADD TO CART
14
Suspension Stabilizer Shaft Link
20784687Link
HHR. Performance suspension. With SS. Connects your vehicle's stabilizer bar to the control arm or strut Provides roll stiffness to vehicle GM Genuine suspension parts match the GM vehicles original equipment in ride, handling and stopping distance GM Genu ...
Just get the 10 inch links. Your choice of many off brands. The 12 inch were only for some Cobalts and maybe some early 2006 HHR’s.
Last edited by firemangeorge; Apr 17, 2023 at 06:32 PM. Reason: Added:::then deleted the addition
Unless there's a problem, get the same length links that you have.
Don't even think about a cheap generic front end kit. Only replace what's needed, except replace shocks, springs, and brakes in pairs.
Disregard anything you read in parts books that say HHR is identical to Cobalt front end.
For part numbers look here : https://www.chevyhhr.net/forums/comm...rt-numbers-68/
navye9ret
22
Jun 19, 2014 11:22 AM
Blue Rookie HHR
19
Oct 22, 2011 04:33 AM
HHorange
May 17, 2009 09:51 PM
