Brakes? (again)
Absolutely. If you haven't had a problem with the stock pads, might as well stick with the same composition for the replacements. I've been using semi-metallic replacements from AutoZone and Advance for years on other vehicles with no problems, but I also tend to get 60-70,000 miles out of a set of pads and never replace or turn the rotors or drums.
Your mileage may vary, of course.
I did have one question about your 'vette. My parents have a '95 coupe and I think the brake booster may be going out. It takes a lot of pedal effort, sometimes two feet, to get the car to stop. Thoughts?
id check it, better safe then sorry
and thanks about the info about the brakes, everyone..i think ill just keep the stock types but get the ones that are about $35 or so
Pads such as Poly D here are way more serious a low temp pad than you'd get from an oem application and thus are great for autcross for example.
http://www.tceperformanceproducts.co..._BP10_BP20.gif
Oldblue
Nov 24, 2013 11:18 AM
mrarff
0
Jan 7, 2011 08:15 AM
