C0201 code fix
Old Jun 26, 2021 | 09:37 AM
timdske's Avatar
C0201 code fix
Well I found the reason for my C0201 code. The car is originally from the Suburbs of Chicago and has dealt
with the road salt for many years. The ground going to the ABS module relay was badly corroded. I replaced the connector and that fixed the problem.
Old Jun 26, 2021 | 09:47 AM
Thank you for confirming my suspicions, as I always say, check for for loose or corroded connections and ground wires.
Old Oct 14, 2021 | 09:44 AM
scubanut's Avatar
Where do you find the EBCM and the grounds? I have the same issue with my 2010.
Old Oct 14, 2021 | 09:53 AM
timdske's Avatar
Ground location
It's on the driver's side front fender next to the ABS module.
gag
Apr 12, 2024 07:13 AM
OKIE SS
38
Aug 22, 2016 07:03 PM
PanamaJack
Jul 11, 2016 10:14 AM
tomiscool
Jan 6, 2015 07:17 AM
chefan
Feb 9, 2013 07:35 PM
