Control arm help
Subscribe
Nov 7, 2012 | 09:16 PM
Just a quick note. When you take the pinch bolt loose on the ball joint, take it all the way out. The ball joint wont come out if you don't.
Don't ask me how I know.....
Reply
Nov 19, 2012 | 02:25 PM
thanks like to know what torque specs are?also anybody live in Ohio,trying to find out if autoparts123 are still in business ? I have called there and all i get is a answer machine and there website will not let you order anything ,all it say that the part is not in stock even if you click on spark plugs do not know whats going on there order all the time ... any suggestions thanks
Reply
Nov 19, 2012 | 04:30 PM
when is it time to replace the control arm? what are some symptoms?
Reply
Nov 19, 2012 | 10:07 PM
Well i have about 150000 miles on her had replaced all the brakes front and rear ..so know i can feel the steering wheel shake back and forth at any speed ,checked my control arm bushing in the rear and sure enough the bushing is tearing up in the back where bolt that goes to the frame near the firewall ..so im going to replace both of them...
Reply
Subscribe
