Cruze coilovers
Old Jan 14, 2015 | 12:30 PM
Twistedtat's Avatar
Cruze coilovers
I found a set of used adjustable coilovers that are on a cruze. The Cruze and the HHR are the same plarform supposedly, so I was wondering if they would work?. If anyone has any info on this its appreciated.
Old Jan 14, 2015 | 02:32 PM
07azhhr's Avatar
They are similar platforms. Ours is the Delta platform while theirs is the Delta II platform. I do not know all that was changed but I do know they redesigned the rear suspension for the Delta II platform. But that does not mean that they did not retain certain parts. You may get lucky. Although keep in mind that the Cruze weighs less than an HHR so spring rates may not be the same.
Old Jan 14, 2015 | 03:10 PM
Twistedtat's Avatar
This is true. Ill have to check that also.
Old Jan 14, 2015 | 05:43 PM
I would go to a site that sells coilovers for both the HHR and Cruze. Look up the part numbers for both. If they're different, then chances are they won't fit or if they do somehow fit would be non-compatible.(spring rates different or else as mentioned by 07azhhr )
Old Jan 16, 2015 | 07:03 PM
Twistedtat's Avatar
Thanks Guys.
Old Jan 18, 2015 | 10:47 PM
07azhhr's Avatar
Did you find any definitive answers? It is always nice to find parts that fit our cars but are sold for other cars in the same family. Especially when those parts may be cheaper for the other cars since they are more mainstream than our cars.
Heavywrecker
Canadian Mid East
Apr 29, 2014 07:02 PM
HillsdaleHHR
Feb 22, 2011 03:46 PM
solman98
Oct 28, 2010 08:59 AM
HillsdaleHHR
Sep 16, 2010 09:50 AM
IgottaWoody
North East
7
May 20, 2010 07:28 AM
