Difference in Suspension packages?
Old Aug 6, 2008 | 02:35 PM
JoeR's Avatar
Originally Posted by Tuanies
FE5 = SS
The SS is stiffer, so thicker sway bars, stiffer spring rates, etc...
Dunno about the other ones though.
Actually the SS front bar is smaller that the others.
All the "regular" HHRs have a 25 mm front bar. The SS is 23 mm.
The rear bar on the "regulars" is 22 mm. SS is 24 mm.
Old Aug 6, 2008 | 03:31 PM
ZTony8's Avatar
Yeah,Snoop changing those CAN change the handling-sometimes for the better,sometimes not.Depends on the shock valving and/or your expectations.Tighter valving will stiffen the low speed ride,looser valving will soften it at the expense of more roll.What do you prefer?
Old Aug 6, 2008 | 09:04 PM
SnoopHHR's Avatar
I have close to 70K miles on my '06 and will most likely be needing replacements soon. I have the 17" tires and would like to keep the sport feel to the suspension. Are there specific GM parts for the 2LT that would keep the FE3 package intact? How would you select aftermarket parts with the proper valving? Thanks for your input.
Old Aug 7, 2008 | 09:23 AM
ZTony8's Avatar
The struts and shocks are the main difference between the 2 packages(the front bar bushings are the only other difference).If you want to use aftermarket pieces,look for items listed as "sport" or "heavy duty" or possibly "towing".These may very well be stiffer than original GM,but with that many miles on your car anything will feel stiffer than what's on it now.
Wifes07LT
10
Aug 4, 2015 03:39 PM
JMichael
Oct 23, 2012 05:19 PM
kayakjax
21
Sep 29, 2011 09:11 PM
damronjr
33
May 17, 2009 10:22 AM
barberpole
2.4L Performance Tech
11
Feb 25, 2008 10:31 PM
