Disks Brakes
Old Mar 24, 2006 | 07:03 AM
O6ChevyHHR's Avatar
will that conversion kit work its ment to be for the cobolt, but the HHR is based on it?
Old Mar 24, 2006 | 08:26 AM
hvrod's Avatar
I haven't seen the kit for the cobalt.. But I believe its probably the same..conversion kit...
Project for this morning.. install the rear disc calipers...
Old Mar 24, 2006 | 11:04 AM
O6ChevyHHR's Avatar
let us know how the install goes.
Old Mar 24, 2006 | 06:47 PM
hvrod's Avatar
I did the install.
Have some concerns with GM....
When I was removing the (4) bolts that hold the mounting plate & mounting spindle for the wheel... the nuts were just above snug..not real tight.. You all should check yours also... When I did my install , I was sure to make sure those nuts were loctite in (Used blue ) (Red is pernament)
Old Mar 26, 2006 | 08:08 PM
Airborne_Beachbum's Avatar
Well, disappointing news, I checked with the parts dept. at the local dealership about Cobalt disk brakes - they were no help. Then, I tried Pep Boys to see if they could help, none there. They said to try the local custom shop. So, I will hopefully get there this week and see if they can help. More to follow after I talk to them.
Old Mar 26, 2006 | 09:21 PM
hvrod's Avatar
Talking
Heres upgrades what the rear part of the vehicle has gone thru.
Old Mar 27, 2006 | 02:24 PM
O6ChevyHHR's Avatar
looking good let us know how they work!
Old Mar 27, 2006 | 03:57 PM
hvrod's Avatar
I need to do a few more things to the vehicle
To really check out all the components out..
But to tell you this.. there is a big stopping difference disc vs brake shoes.
Old Mar 27, 2006 | 04:04 PM
SoCalHHR's Avatar
Did the kit include a new brake proportion valve? You will need one to prevent rear lockups under hard braking when switching from drums to discs.
Old Mar 27, 2006 | 07:21 PM
hvrod's Avatar
No extra valves... I believe the ABS system, takes care of the locking up of wheels/brakes.
Mike, hows the sway bar deliveries looking ?
