Disks Brakes
After removing the wheels, you should stuff some newspaper around and behind the drums to stop overspray. Then use a wire brush to bust off some of the rust. I like to wipe off the rust dust with alcohol on a rag, then let air dry. Shoot a few light coats on the drum being careful not to get too much on the stud threads. Let it dry a few minutes and put the wheel back on.
Repeat for other side!
I used a Krylon Rust Tough Enamel - Flat Black, found in the Auto paint section of my local Kragens. I also taped off each stud. The Flat black perfectly matched the existing black very well, so all I needed to do was the exposed area that was rusted. I did not have to coat the whole drum.
Originally Posted by HHR PNOY
one more thing, would any high heat engine paint do? I've seen paint kits for caliper breaks being sold and was wondering if that's the only option I have.
Good luck with it!
Oldblue
Nov 24, 2013 11:18 AM
mrarff
0
Jan 7, 2011 08:15 AM
