Eibach Pro Drop kit
Old Sep 1, 2006 | 10:58 PM
larryv's Avatar
No Rubbing!
Rear wheel wells have been trimmed. I used a snap-on air saw blade and trimmed 15mm or about a 1/2 an inch. Took about 15 min a side then sanded smooth and used 3M undercoating to protect the exposed metal. She drives the car daily and no rubbing what so ever if the wheels rubbed I would be the first one to pull them off. I will take some pictures of the rear tires this weekend and I believe she has put about 3k miles on the car since. Thanks
Old Sep 2, 2006 | 08:31 AM
O6ChevyHHR's Avatar
Are those 20s
Old Sep 2, 2006 | 08:32 AM
O6ChevyHHR's Avatar
and this has the Drop kit i want on it right.
Old Sep 2, 2006 | 09:18 AM
RUDEINC's Avatar
Trimmed Wheel Well.........
Larry, here is the picture you sent me............
Old Sep 2, 2006 | 01:26 PM
SoCalHHR's Avatar
Yeah, I'd just like to see that same pic after 3k miles...
Old Sep 2, 2006 | 02:48 PM
O6ChevyHHR's Avatar
20s??
Old Sep 2, 2006 | 05:02 PM
20s??
This should cover all you want to know.............
(its amazing what using the search will get you)
Originally Posted by larryv
I finished a female friend of mines HHR today. I started with a set of Eibach springs, didn't want to go real low. Was limited on the wheels with a 5x110 bolt pattern so she decided to go with these hub centric 20x8.5 with a 35mm offset. As for tires we went with the BF KDW2 245/30/20, they have a 300 treadwear. Rear outer fenders where rolled just in case, don't want to cut up the new tires. I was suprised with the ride, not bad at all! All in All she is very happy and I enjoyed doing it for her. Oh! can't forget the stubby antenna from SoCalHHR's. Larry in Calif.
Old Sep 2, 2006 | 05:11 PM
crowbar's Avatar
I installed the Eibach pro kit for a female friend of mine and the ride is pretty comfortable the pro kit lowered the HHR about 1in in all four corners so aligning the HHR was no problem. The only firmness felt was from the 30 series tires, but all in all you got to love the HHR! Here are some pictures.
Old Sep 3, 2006 | 11:49 PM
larryv's Avatar
Here you go SOCAL!
I took some pictures of her car today, 2800 miles have been put on the HHR since the lowering. Sorry for the quality of the pictures but I used her camera. The car is driven daily and has had 3 people at one time and no rub marks on the rear tires. If i had not trimmed the rear fenders the tires would have been cut up pretty good. Here are some pictures of each side.
Old Sep 4, 2006 | 08:14 AM
O6ChevyHHR's Avatar
Thanks for the info !
