Eibach or Progress?
Old Jun 29, 2006 | 09:40 PM
Clarke33's Avatar
Originally Posted by JOEK86
Other than the small difference in drop, about 1/2", are there any advantage or disadvantages to either? Experiences and thoughts please............
Joe
Has anyone dropped just the rear to level theirs out?
Old Jun 30, 2006 | 12:53 AM
HHR PNOY's Avatar
I have 7.5's with 45 offset...no rub.
Old Jun 30, 2006 | 12:58 AM
SoCalHHR's Avatar
Right - because the stock offset is 42mm - and since you have more offset than stock, your wheels are tucked in slightly more. Make sense now?
Positive offset is the reverse of normal wheel "offset."
Most FWD vehicles have positive offset wheels.
Old Jun 30, 2006 | 08:14 AM
JOEK86's Avatar
So Mike, If I go back to my stock 17" wheels the Gold Line's should work Right?
Also, if I am reading the threads correctly, I should get the camber adjust and shims too?
Joe
Old Jun 30, 2006 | 10:08 AM
SoCalHHR's Avatar
Hi Joe, I ran the Gold-Lines with my stock wheels for 6-months with no issues, and several others (with both 16 & 17's), have done so also. You just need to make sure that if you are buying new aftermarket wheels, they have the proper offset to stay tucked.
Hope it helps,
Old Jun 30, 2006 | 10:35 AM
JOEK86's Avatar
Thanks Mike, I just put an order through to you for the GL springs, shims, camber and sway bar! I am going to try my after market wheels, if they rub I will go back to stock until I can find some AM wheels with spec's that will work.
Joe
Old Jun 30, 2006 | 06:34 PM
grnds4leaving's Avatar
Got my goldlines today from autotrucktoys.com. Will be slaming it Monday!!
Old Jun 30, 2006 | 08:45 PM
Any comments on that Mike?
Old Jun 30, 2006 | 08:49 PM
SoCalHHR's Avatar
Sure: old stock. No one has the new ones yet.
Old Jul 4, 2006 | 08:44 PM
dan-d's Avatar
Joe
Joe, I don't know if you found the answer to your question and don't know if I can shed any light on it or not. I had the gold lines on my HHR and they worked out great, but I didn't know that Progress made springs for the hHR. However, knowing Progress springs I can say that they do make a quality product. I had a set of Progress springs on my Focus and they performed great. As a matter fact I've sold the car and the progress springs are still on there doing their job. -Dan
whitelightnin
Feb 15, 2013 11:25 PM
rockNroad
61
Sep 27, 2007 04:21 PM
JArcudi
Jun 10, 2007 11:31 PM
rockNroad
Apr 10, 2007 05:56 AM
