Front End Clunking
Old May 2, 2011 | 08:35 PM
djr1973's Avatar
I know there has been other members that have had the key stuck issue, think that is something in the sterring column itself. As far as the clunking, if it does it when you go over bumps? If so that would be sway bar end link issues( I had one come apart on my other HHR), but if it clunks when you turn the steering wheel, that has to do with the intermediate shaft in the steering. Either issue it is ok to drive for a lil bit, but would recommend gettin it checked out and fixed soon though.
Old May 2, 2011 | 08:38 PM
djr1973's Avatar
What part of Ohio are you in?
Old May 24, 2011 | 02:13 PM
kmcrae476's Avatar
Smile
So I finally got a chance today to have the clunking noise checked out at a local tire/suspension shop I use. Turns out the clunking is the strut bearing. Gave me a price of $368.00 and change to fix it, or $658.00 and change to replace the struts. The quick struts are sounding more like the way to go....new spring, strut, mount plate and bearing for approximately $235/set. Shop stated the sway bar bushings and end links looked fine.......for now at least. Thanks everyone for all of your posts, replies and advice......I love this site.
Old May 24, 2011 | 05:09 PM
QuickRick's Avatar
Be very careful
KM,
Be very careful with that diagnosis; I hate to sound presumptious but, we know more about HHRs than most shops.
More of us have seen this problem than the shops have, so if they are not HHR experts they are just guessing at what it "could be" or "usually is".
QR
Old May 24, 2011 | 05:39 PM
Zagohhr's Avatar
Originally Posted by QuickRick
KM,
QR
x2... I received the same answer on a shop about 2 years ago... I would purchase two sway bar bushings ($30) and install them... begin from the cheapest solutions ALWAYS!!!!
Old May 24, 2011 | 11:02 PM
kmcrae476's Avatar
Thanks everyone for the advice. I was already leaning towards the sway bar busihings first and then see how it sounds. After that (if the problem still persists) I am going to switch out the struts using quick struts myself and then the end links if the problem still hasn't been solved. Again, I appreciate everyone on this site looking out for each other and offering help.
woodycom
May 24, 2013 11:59 AM
capp002
Jul 17, 2011 07:47 PM
DanH
Oct 5, 2010 01:41 PM
whiteyHHR
Jun 19, 2010 01:44 PM
HHR-VTX
Jan 7, 2009 10:58 AM
