Front strut service life ?
Old Jan 19, 2011 | 08:47 AM
SmootHHR's Avatar
I found the struts on ebay for $62/strut SHIPPED from roadtripoutfitters. Partstrain.com had the KYB shocks for $57 shipped...for the pair.
oh, for anyone looking for hub assemblies, also found on ebay for $75 shipped (non-abs) from Dearborn Axle.
Old Jan 19, 2011 | 10:21 AM
PhoS's Avatar
Originally Posted by SmootHHR
I just did KYB's up front with the SS springs
https://www.chevyhhr.net/gallery/fil...4464700002.jpg
Anyone ever see a floating HHR? haha
https://www.chevyhhr.net/gallery/fil...1459070001.jpg
To the best of my knowledge, the previous owner never did front struts on my HHR...I've put 20k on it (108k now) and just did the struts. They were absolutely smoked! Next to NO pressure on them at all. We turned them upside down and stood them up on the "post" and the weight of the strut itself started to push the post in. To my surprise most, if not all, of the clunks are gone in my car. Shoulda done them with the rear shocks I did this summer, but didn't have the loot. BTW, my struts were NOT leaking, so for what it's worth, the "if they not leaking they not broke" theory isn't correct, at least in my case.
I would expect the stock struts to last 40k at most , maybe 60k with an old lady drivin. Personally would take the FE5s over the KYBs but anything is better than stock
Old Jan 19, 2011 | 12:07 PM
SmootHHR's Avatar
The guy I bought it from (family member) literally drove it about a mile to the highway, 40 miles south, another mile to the office and back everyday. Literally ALL highway, everyday for 4+ years. He didn't replace the stock front rotors or tires until 74k. I have the receipts as proof. I asked him repeatedly if he had any other work done...even went to the dealer that he had all the work done at to see the records.
Old Jan 20, 2011 | 10:35 PM
jay loukakis's Avatar
I got the Moog links k750012 $22.99 each plus shipping, thay made a big diffrence.
Old Jan 29, 2011 | 07:54 PM
mrarff's Avatar
Originally Posted by Lucky
struts are an big money maker in the repair industry. if the oil or the gas&oil inside a strut don't leak out the struts don't lose there damping ability. so unless its making noise,rusted out or the valves inside have broken which is very rare it should in no way be unsafe. I have seen lots of struts go for 100,000 mile plus and they are still going strong with no excess tire wear or danger. This is my opinion based on being an auto tech of 18 years. with that said if you have the money to send and you want peice of mine then by all means replace them as often as you like but I beleve that there money will better spent fixing the noise which is probably sway bar links and or bushing as was mentioned by 843de above.
The rear shocks I removed from my son's '08 Cobalt rode ok, did not leak, but it only took about 2 lbs of force to collapse them (and it took about an hour for them to fuly rebound).They had 68k on them. Preventive maintenence is not a sign of being anal-retentive, it's a better and smarter way to spend money than for DUBs, fancy paint schemes & such. Just MY two cents. BTW , I replace sway bar end links, sway bar bushngs, timing chains/belts ect before they MAKE me do it. Just about every part on a modern vehicle has a time or milage life expectancy.To ignore such things is like a drunk man in Vegas with a 20k limit on his Visa.
Old Jan 29, 2011 | 08:08 PM
  #26
mrarff's Avatar
Originally Posted by jay loukakis
I just had the links replaced went with the Moog the bushings were fine but have ordered the regreaseable one wont be here until next week, rides like new.
Just curious, but you stated that you turned wrenches for 18 yrs. "I had the links replaced". Don't you do your own wrenchin anymore, or did I misunderstand? If so, I offer my humble regrets.
Old Jan 29, 2011 | 08:15 PM
  #27
mrarff's Avatar
Glad to here it worked out for you. let me know how the greaseable bushing work for you. I have never seen how those work or what they look like.
They have a grease zerk on top of the housing which is oriented to a hole in the poly bushing. This "hole" goes all the way through to the sway bar. The grease zerk goes partway into the bushing to keep it from rotating out of place.Hence this is how the grease gets to where it is supposed to go. They've been on the market for around 20 years.
Old Jan 29, 2011 | 08:49 PM
  #28
Lucky's Avatar
We were instructed by the factory never to grease sway bar bushing because it would attack the rubber and shorten the life of the bushings however the poly bushings shoud hold up to the grease. The factory also instructed us that the bushing is to hold the sway bar tight to limit rotation to get a stiffer supension. So I my concern would be alowing the sway bar to twist more than designed may shorten say bar life. Now this was the thinking back in the 80's when a lot of the cars where breaking sway bars. I'm sure the steel is better now then back in the 80's
Old Jan 29, 2011 | 08:52 PM
  #29
urbexHHR's Avatar
Wasn't that back when half the steel was from Japan, and it would rust right away? Or was that the 70's?
Old Jan 29, 2011 | 08:55 PM
  #30
Lucky's Avatar
late 70's/ 80's and early 90's I beleve
