front sway bar size
Old Nov 14, 2015 | 08:20 PM
zapshd's Avatar
front sway bar size
ok, i give up, after searching for over an hour, and reading conflicting answers.
what size front sway bar do I have on a 08 LS panel? I just installed the TTR
rear sway bar which is 1". definitely an improvement but everything ive ever read has said you should never have a larger rear than front swaybar.
what size do i have and would a larger front help?
Old Nov 14, 2015 | 08:27 PM
Lucky's Avatar
You should have a 25 mm front sway bar 25 mm converts to 0.984252 inches.
I don't think you will have any problems being a little bigger in the rear.
Look at your rpo code in the glove box. Should find a FE1 or a FE3.
If I remember correctly the FE3 is the 25mm and the FE1 is the 23mm
Old Nov 14, 2015 | 09:46 PM
My 2007 LS 2.2 has s 25 mm front bar and has FE1 suspension.
The 2006 and some early 2007 LS/ LT had the 23mm front swaybar, this was beefed up to the 25mm bar from mid 2007 to 2011.
The 2008 to 2010 SS had the 23 mm swaybar .
If it's the front sway bar bushing kit you are looking for its the energy suspension 9.5161 polyurethane greaseable kit you want.
Check here under suspension front swaybar bushings
https://www.chevyhhr.net/forums/comm...-part-i-48833/
Old Nov 14, 2015 | 11:24 PM
Good job Oldblue, you're doing great pointing folks in the proper direction.
Old Nov 15, 2015 | 12:56 AM
Oldblue nailed it again!!!
My early 2006 has the 23MM bar - FE1 - I found that out after installing the 25mm poly bushings and discovered the bar rattled worse than with the worn out original bushings (23mm).
Old Nov 15, 2015 | 08:40 AM
zapshd's Avatar
guess ill have to measure it, real question is should i be concerned rear is larger than front, usually a big no no
Old Nov 15, 2015 | 09:10 AM
Why would you have to measure it , we gave the dimentions and the part numbers.
Your 2008 HHR Panel will have the 25 mm swaybar which is a 1 inch swaybar!
the front and the rear are both 1 inch, I been running this setup for 150,000 miles and I'm sure others have too.
no worries about a big no no!! your ride won't get hairy!!
Old Nov 15, 2015 | 09:29 AM
zapshd's Avatar
thanks
Old Nov 15, 2015 | 09:35 AM
You're welcome
Old Nov 12, 2021 | 10:01 PM
valhallah's Avatar
Lightbulb Hhr 2008 LT sway bar bushing size recommendation
Good evening team. Quick question. I’ve bought non OEM sway bar bushings for my 2008 LT and they are 1 inch bushings. However, there’s still play and clunkyness. Will buying 24mm bushing still fit ?
