Hissing sound from under dash
Old Oct 4, 2011 | 05:24 PM
Gol10dr's Avatar
I have an 2007 HHR with 93 K on it, and I noticed to day there is a hissing sound, (or air escaping sound coming in from under the dash.) the sound isn't my a/c, shut it off, sound is still there. But the sound goes away when I press on the brakes, making me think it's something with my brakes. I turned the car off and the sound slowly dissapaited.
Any ideas would be helpful, and please no snake jokes..
****I just noticed that the boot that goes from the back of the brake pedal to the firewall appear to have some leakage at the bottom of the boot.****
Old Oct 4, 2011 | 09:38 PM
Sounds like a leaking brake booster.
Old Oct 5, 2011 | 01:08 AM
Either a leaking brake booster or the vacuum supply line going into it.
Old Oct 5, 2011 | 08:36 AM
Gol10dr's Avatar
Maybe, the funny thing is... The "hissing" sound has went away, but it threw a engine code of P0171.. So now I'm really stumped... Because if my memory serves me correct, the is an O2 sensor code..
Old Oct 5, 2011 | 10:26 AM
solman98's Avatar
OK........
Old Oct 5, 2011 | 10:29 AM
Sounds like you have a broken or leaking flex pipe, they'll throw a P0171 if the oxygen sensors are reading lean due to an exhaust leak. Give this thread a read....
https://www.chevyhhr.net/forums/problems-service-repairs-42/catalytic-converter-p0171-27304/
Old Oct 5, 2011 | 11:29 AM
Could be dealing with 2 seperate issues. I refer to the OP's original post.
" I turned the car off and the sound slowly dissapaited" This quote sounds like a brake booster/vacuum leak not a flex pipe issue. The CEL that popped up seems to be from something else. Just my 2 cents, based on the original post.
Old Oct 5, 2011 | 04:41 PM
Yeah firemangeorge, he might have a combination of issues, its an unlikely combo but not impossible I suppose.
Old Mar 15, 2012 | 09:39 PM
robinbraves's Avatar
Question Whistle noise
I was thinking i was the only one who thought i had a brake booster leaking. The other day i noticed my brake pedal felt soft. Was going down farther
than it used to. Then i heard a whistling noise when i let off the brake. Took it to a GM dealer to make sure. Said all was fine. I know a soft pedal when i feel one. I work in a new car dealer parts dept. Not Gm. Tech thinks its leaking booster also. Anyone else had to replace a booster?
Old Mar 15, 2012 | 10:56 PM
Sounds like the master cylinder may be leaking. Check the brake fluid level..
