Hissing sound from under dash
I was thinking i was the only one who thought i had a brake booster leaking. The other day i noticed my brake pedal felt soft. Was going down farther
than it used to. Then i heard a whistling noise when i let off the brake. Took it to a GM dealer to make sure. Said all was fine. I know a soft pedal when i feel one. I work in a new car dealer parts dept. Not Gm. Tech thinks its leaking booster also. Anyone else had to replace a booster?
First off,you might want to check your rear brake adjustment. The HHR is notorious for the rears to get out of adjustment. This might get your pedal height back to normal. If not,then on to checking the master cylinder or booster.
Let us know what you find out.
GinaM
May 25, 2014 09:50 AM
nacademus
Sep 12, 2013 08:28 AM
