Hissing sound from under dash
Old Mar 15, 2012 | 11:54 PM
Originally Posted by robinbraves
I was thinking i was the only one who thought i had a brake booster leaking. The other day i noticed my brake pedal felt soft. Was going down farther
than it used to. Then i heard a whistling noise when i let off the brake. Took it to a GM dealer to make sure. Said all was fine. I know a soft pedal when i feel one. I work in a new car dealer parts dept. Not Gm. Tech thinks its leaking booster also. Anyone else had to replace a booster?
Some cars will make a swoosh noise if the brake pedal goes down lower than normal. I think it is the rubber boot on the booster sucking or blowing air when it gets overextended. I used to notice it sometimes when I was the brake "pumper upper" during a brake bleed job.
First off,you might want to check your rear brake adjustment. The HHR is notorious for the rears to get out of adjustment. This might get your pedal height back to normal. If not,then on to checking the master cylinder or booster.
Let us know what you find out.
ANN ARBOR MI
Jun 2, 2015 07:12 AM
GinaM
May 25, 2014 09:50 AM
nacademus
Sep 12, 2013 08:28 AM
teknolla
Apr 27, 2013 11:01 AM
Leonard
Canadian Mid West
May 28, 2012 06:21 AM
