Inner Tie Rods
Old Sep 8, 2016 | 11:15 AM
pbatmen's Avatar
i replaced them myself, super easy, I recommend replacing both inner and outer, rent the inner tie rod tool from your local auto store, Advanced auto by me had one and it worked great.
Old May 19, 2017 | 06:32 AM
SuKi's Avatar
Bringing it back again. I just did mine. One of the joints, whether the ball or socket failed, I don't know, hung limply with the outer rod end removed.
You will probably render the factory clamp on the rubber boot on the rack useless when taking it off. I used a large zip tie to replace the metal clamp on mine. The small spring steel clamp on the outside is reusable.
ColeTrickle
Jan 12, 2019 12:10 PM
hhrlover101
Sep 6, 2012 06:06 PM
