Ksport Coilovers
Old May 11, 2014 | 08:51 AM
Originally Posted by mississippisunburst
ZZ Performance says:
Looking for big brake upgrade? This is a 14.5" front brake upgrade kit that uses a genuine Brembo 4 piston caliper.
This will fit perfectly behind factory LNF wheels that are setup for the factory Brembo brake option.
To run this kit on a factory non Brembo caliper wheel, you would need to replace your stock wheel studs with a set of ARP wheel studs, and install a 1/4" wheel spacer on each side.
We have not tested fitment on any other wheel.
Fits 5 lug Cobalt
Sold as a front kit.
Got it. Thanks for the info.
I have the Brembos on mine. I think the rotors are like 12.3". The clearance between the caliper and rim is about 9/16".
That's why I was curious about the fitment of a 14" rotor.
Still a little confused by their wording of a "factory Brembo wheel" and a "non Brembo caliper wheel". Guess that's just a Cobalt definition.
Old May 12, 2014 | 02:07 PM
mississippisunburst's Avatar
This kit uses the rotors and brembo calipers from the rear of a 2010 camaro ss, ZZ Performance fabricates custom caliper brackets. All 18" double spoke wheels on 08 to 10 hhr ss are brembo compatable.
Old May 19, 2014 | 10:21 AM
Judges liked the stance, 1st in class at Showfest 2014!!!
Old May 19, 2014 | 11:01 AM
chefhhr's Avatar
I'm guessing you didn't run it in a modified class...I know most stock classes let you have up to 3 major modifications.
Old May 19, 2014 | 12:18 PM
This show does mild, wild, extreme, and radical within each class. this time i was mild compact car domestic, go figure.....
Old May 19, 2014 | 12:35 PM
  #26
chefhhr's Avatar
Oh cool! Since it looks like I'm keeping my wagon I'll have to take it to a show one day and see how I do.
Hey report back in after a few hundred more miles on those Ksports...I'm curious to see if you start having any creaking sound in the rear. I developed this noise pretty fast with mine...you can't hear from the outside but it's very noticeable at slow speeds. It's like a rubber against rubber sound.
Old May 19, 2014 | 12:59 PM
  #27
nothing in the rear yet, but my swaybar end link mounting brackets needed repositioning up as far as they will go, the swaybar was clanking against something. i'll keep posting....
Old May 19, 2014 | 02:04 PM
  #28
chefhhr's Avatar
I haven't had an issue with that but I had mine positioned as far up the strut as I could get them...only noise I have is from the rear and it's sounds like a creaky old mattress. I looked online and found that at least one other Cobalt owner experienced the same issue. I'm as low as I can go in the rear...all lock rings removed...damper setting at 10 from the firmest...ride is pretty rough in the rear.
Old May 19, 2014 | 03:15 PM
  #29
the rear is where i don't care for the ride, it seems to crash on certain bumps. LOVE THE HANDLING. Tired of jacking and lug wrenching wheels on and off.
Old May 22, 2014 | 07:23 AM
  #30
chefhhr's Avatar
Hey if you start getting the squeaky bed sound...take some wd40 to the rear trailing arm pivot areas. Apparently our wagons don't like the extreme angle when dropping it that low in the rear.
